Testing the market. What is this LT1 engine worth?
Old Feb 16, 2003 | 09:46 PM
ucrazymonkey's Avatar
97 LT1 110,000 miles. Stock Engine except the following: Heads have been replaced with 95 Corvette Lt1 heads including a full rebuild. Comp Cam Push Rods, Summit Guide Plates, Crane 10308-1 Spring Retainer Kit, ARP Head Bolts and Screw in Studs, 1.6 Summit Roller Rockers with 7/16 Stud. heads have a 3 angle valve job and have been milled 10,000 ths. They have 4000 miles on the heads. New GM Harmonic Balancer. New GM Water Pump Casing, and Meziere Electric Water Pump. Felpro Performance head Gaskets and Intake Gaskets. Pulled 275 RWHP while running a 2800 10" Conveter. True RWHP should be around 305 RWHP. It would be a complete engine ready to go in. What would you guys think it is worth?
Old Feb 17, 2003 | 12:10 AM
Zjoker's Avatar
I though 95 vetts and z28 had the same heads?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Injuneer
Dec 15, 2014 09:36 AM
naaz90
Jul 27, 2002 08:22 AM
