Testing KS resistance??
Old Jul 17, 2006 | 05:42 PM
Sweetred95ta's Avatar
Testing Knock Sensor resistance??
I'm trying to do this but I can't get my multimeter to read anything. I am setting it on the 200K ohm (100 ohm resolution) setting and putting one terminal in the KS and the other on the oil pan stud that grounds the pcm. I can't get it to read for ****. It is just reading 1 like it is too much resistance. The key is off and the KS wire is unhooked. What am I doing wrong? I am new at this, so any help would be appreciated.
Old Jul 17, 2006 | 10:31 PM
Re: Testing Knock Sensor resistance??
Try a lower range on the meter... you're only looking for 4,500 ohms. Are you sure you have the probe wires plugged into the "ohms" sockets on the meter?
Old Jul 17, 2006 | 10:55 PM
Re: Testing KS resistance??
I'm sure I have the wires in the right sockets. There are only 3 and the third is for 10A (whatever that is). Ah, I was thinking 45K ohms. I still think I tried everyone to see if I could get a reading and I couldn't. I can do the 20K ohm setting (with 10 ohm resolution) and try again. I just stick the red probe into the sensor and the black probe to some grounded metal, right? I'm sorry to bug about such a simple concept. I thought it would be easy and then I couldn't get a reading and I felt like a dumba$$. I appreciate the help Injuneer.
Nayr
Mar 3, 2023 08:34 PM
Aaront810
Aug 29, 2020 09:34 PM
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
