Testing coil?
Old Sep 30, 2006 | 03:10 PM
z28 justin's Avatar
Testing coil?
I've been having some ignition problems and before jumping on the Opti wagon and spending $200 for something that might not be the problem I want to check my coil. I have a Crane Cams PS91 coil and heard you could check them with an ohmmeter. Can anyone chime in with some info? Thanks.
Old Sep 30, 2006 | 03:15 PM
Re: Testing coil?
This will test continuity and for excess resistance.
Old Sep 30, 2006 | 03:45 PM
z28 justin's Avatar
Re: Testing coil?
My coil only has 2 terminals though, not 4. 2 metal prongs that the plug connects to and then the high power output.
Old Sep 30, 2006 | 03:49 PM
Re: Testing coil?
You don't have a stock type coil?
Old Sep 30, 2006 | 03:53 PM
z28 justin's Avatar
Re: Testing coil?
Nevermind, I found the specs on Crane's website.
Primary Resistance .43 ohms
Secondary Resistance 3.0 kohms
Is there any other way to test a coil?
greenzee28
Mar 26, 2015 09:13 AM
naaz90
Jul 27, 2002 08:22 AM
