Test port valve size?
Old Nov 29, 2003 | 11:06 AM
1FastRedZ's Avatar
Is the fuel pressure shrader(sp?) valve the same size as one in a tire?
Old Nov 29, 2003 | 11:12 AM
AsianSensation's Avatar
It's a little bigger.
Old Nov 29, 2003 | 12:17 PM
formula383's Avatar
I read on here before that you could use the valve out of the spare tire, so it should be tha same as a tire is that is correct.
Old Nov 29, 2003 | 12:41 PM
According to a post I saw by Injuneer, the valve is a -4AN.
Old Nov 29, 2003 | 12:50 PM
The cap on the fuel rail schrader valve won't fit on the wheel schrader valve.
Old Nov 29, 2003 | 01:01 PM
formula383's Avatar
The cap won't fit, btu I read on here that the schrader valve will fit in the test port.
Old Nov 29, 2003 | 01:16 PM
You can remove the fuel rail schrader valve with a tire valve core tool. That doesn't necessarily mean the two port size are the same size. Dunno, maybe I'm dumb.
Old Nov 29, 2003 | 06:53 PM
gb95zconv's Avatar
This is true.....I tried a standard tire valve once....too small.
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
naaz90
Jul 27, 2002 08:22 AM
