Is this bad, or ok??????
Old Nov 29, 2003 | 05:36 PM
95patriotZ's Avatar
I put a new pilot bushing in onmy 95 z. I heard is it supposed to be flush with the crank when in. Mine is a tad bit deeper in than flush. Not a whole lot, but it is in a little further. Will that matter, if it does, how do I get it out to make it flush. Or will it not matter. Any help would be great. Thanks guys!
Old Nov 29, 2003 | 05:47 PM
drewstealth's Avatar
well you can use a pilot busing puller to pull it out some. But it is really close to being flush then i wouldn't even worry about it. You can be off a little and be okay.
Old Nov 29, 2003 | 07:23 PM
Heatmaker's Avatar
Advanced Member
The pilot bearing pullers tend to damage the bushings. Do the toilet trick and put it back in if it isn't flush.
"If you have to worry about it, it's probably a problem."
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
