Tensioner not doing its job!!!
Old Jul 22, 2004 | 05:26 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
So my belt was screeching alot and the battery voltage was dropping today on the way home so i pulled it onto ramps and the tensioner thingy ( I think you call it) is not providing any tension. When i take the wrench to it and try to put it in its right place and take the slack out, it DOES, but then goes right back! So i guess my question is. Where do i get it and how hard is it to replace and i guess, is it expensive???? THANKS!
Chris
Old Jul 22, 2004 | 05:39 PM
CamaroBoy96Z28's Avatar
Re: Tensioner not doing its job!!!
Tensioners cost ~$20 and takes all of 5 minutes to put in. 2 10mm bolts and you're done. You dont even need to jack up the car although it would be easier. You can get a new OEM one from the dealer or go to Autozone, NAPA, etc.
Old Jul 22, 2004 | 06:09 PM
Sweet. Thats what i wanted to hear. Thanks alot man.
Chris
Old Jul 22, 2004 | 07:29 PM
Just got one from autozone and put it on. Problem solved. Gotta love this forum!
Chris
Old Jul 23, 2004 | 11:01 AM
Awesome
Old Jul 23, 2004 | 12:03 PM
Makaveli's Avatar
thats what i wanted to hear, gotta do mine this weekend
Old Jul 23, 2004 | 12:25 PM
I'd check for a stretched/worn belt before I started replacing the tensioner. There is a "pointer" on the tensioner frame. To work correctly, the pointer needs to be in the marked range. If the pointer is outside the marked range, your belt has stretched and replacing the tensioner isn't going to help a bit.
There's a spring in the tensioner... trying to force it into a new position with a wrench isn't going to accomplish anything. Its meant to spring back.
So.......
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 18, 2015 07:08 AM
Catmaigne
Jul 14, 2015 05:17 PM
