tensioner going bad?
Old Jul 24, 2006 | 09:06 AM
contraststriker's Avatar
My serpentine belt sometimes moves rearward one rib on the crank hub...this has destroyed one rip of the belt so far--for the time being I just carry around a 13mm wratchet and move it when I notice it has moved back again. I just recently drove it 200 miles consistently under 3000 rpm, never going WOT. However, when I really get on it, the belt skips a rib. The tensioner feels good to me, but that isn't a very accurate measure of it. Is it going bad? Is there a torque spec a new tensioner should require to move it?
Old Jul 24, 2006 | 09:24 AM
Blownbird355's Avatar
Re: tensioner going bad?
If your losing a rib it sounds like the pullies are not alighned properly. Has the crank hub been off recently or anything?
Old Jul 24, 2006 | 09:56 AM
It has never been off even though it has been removed more than 10 times...not to say it didn't move this time. But how does the crank pulley change position? It's press-fit AND has three bolts securing it to the hub!
Old Jul 24, 2006 | 10:05 AM
Check the crank pulley for a broken rubber ring. The pulley is also the "damper" and consists of an inner and an outer ring, held together by a hard rubber ring. If the ring is deteriorating, the outer ring of the pulley can wobble. Grab the pulley hard on one side and see if it will move.
Old Jul 24, 2006 | 10:12 AM
I'm confused and can't seem to find these "rings" you speak of.
Where are they, are you talking about some rings between the balancer hub attached to the crankshaft, or something on the harmonic balancer itself? I always thought the pulley was just a chunk of metal, with no rubber or anything on it......I seem to be ignorant.
Old Jul 24, 2006 | 10:22 AM
There's a black line representing the inside diameter of the pulley, and right outside it, another black line representing the seam where the inner and outer rings meet. The rubber ring is inside the two pieces.
Old Jul 24, 2006 | 09:58 PM
I'm not understanding.. you said never been off but then says been off 10 times. Also I meant have you had the hub off it is pressed on and if you didnt get it pressed all the way back on serpentine could be out of alignment.
pimpen1024
Aug 19, 2015 08:36 PM
Xiantyl
Jul 21, 2015 05:42 AM
Jmj93z28
Jul 10, 2015 06:37 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
