tempature climbs after engine is off?
Old Nov 14, 2005 | 01:36 PM
bplemmons's Avatar
Is it normal for the temp gage to climb from 180 to about 240 after the engine is shut off? Is this a sign of air in the cooling system?
Old Nov 14, 2005 | 02:13 PM
izzyz28's Avatar
Re: tempature climbs after engine is off?
It's called heat soak and it's perfectly normal. You'll notice it more in the Summer, especially on really hot days, but even in cooler temperatures you'll see the temp. gauge go up and then eventually start going back down as everything cools off. You gotta remember that when you shut your car off there is still a ton of heat in the heads, exhaust manifolds, pistons, etc..., and that heat needs to go somewhere, so it "soaks" into the engnine block and cooling system.
Old Nov 14, 2005 | 02:17 PM
bplemmons's Avatar
thanks!
DirtyDaveW
Mar 15, 2015 07:01 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Z28countrymama
Jan 22, 2015 02:50 AM
CamaroRSguy
Aug 19, 2002 01:52 PM
pnbarbee
Jul 9, 2002 06:35 AM
