temp went into the RED ZONE!!!!
Old Feb 13, 2003 | 05:59 PM
Hyperspeed97z28's Avatar
Unhappy temp went into the RED ZONE!!!!
is this BAD? i was runnign the car, FORGOT THE AIR PUMP/FANS fuse popped and im working on gettin the rear taillight out to check the bulbs and then its hits me i look at its as far up as it can get, i turn it right off and pop the hood, i can hear the coolant bubbling and boiling in the overflow tank. i didnt screw nething up did i ??? i put a fuse in for the fans instantly after too and they kicked right on.. should i be alright since its like below zero out and it'll cool right off
Old Feb 13, 2003 | 06:14 PM
i wont warp heads or risk the headgaskets will i ?
Old Feb 13, 2003 | 07:03 PM
It depends on how long it was up there and how hot it really was. Symptoms may show up later.
Old Feb 13, 2003 | 07:40 PM
well it was in the red on the temp gauge, almost all the way up as far as it can go, was still running perfectly fine and is, i went out for a drive! it wasnt there more then 2-3 mins like that ? what kinda symptoms?
Old Feb 13, 2003 | 07:43 PM
shocktrp's Avatar
Mine ran fine even with a blown head gasket. I had some coolant come out the exhaust with extra smoke. Another sympton would be coolant in the crankcase oil.
Old Feb 13, 2003 | 07:58 PM
Ill have to check the oil tommorow, I pray the car is ok, im sure it is though cuz it wasnt hot for long....
Old Feb 13, 2003 | 08:02 PM
stik6shift93's Avatar
I did the exact same thing, I turned it off imeditaly and let it cool down. I haven't had any problems since(it happened about a month ago). You'll be fine as long it was only for a few seconds.
Old Feb 13, 2003 | 08:07 PM
yeah it wasnt long at all, i instaly turned her off and put a new fuse in with the car off, fans kicked right on even with the car off , ill check the oil tommorow, should be ok though
reww86
Apr 27, 2015 06:14 PM
Collector Car
Dec 17, 2014 01:12 PM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
