Temp Spiking
Old Feb 11, 2007 | 08:22 PM
CamaroSS8887's Avatar
Temp Spiking
So my car has been pegging the temp gauge once a day whn i drive.it goes to the max then all of a sudden it drops back to 180... I have changed the thermo stat and the fans work so i dont know what it could be. And now the temp gauge doesn't even work.
Old Feb 11, 2007 | 09:50 PM
OBE1 95Z28's Avatar
It might have been a defective temp sensor or wiring to the temp sensor all along, that finally failed.
Here's a link to Shoebox's temp sensor check-out procedure: http://shbox.com/1/4th_gen_tech2.html#ect
Old Feb 11, 2007 | 10:36 PM
seawolf06's Avatar
Sounds like air in the system. Try bleeding it.
Old Feb 12, 2007 | 01:17 PM
I done that several times. and it is always low on coolant but i have checked for leaks numerous times. How does air get into the system other then by taking the cap off.
Old Feb 12, 2007 | 02:02 PM
95LT1conv's Avatar
if its always low on coolant, you need to find out where it is going first.
Old Feb 12, 2007 | 04:04 PM
seawolf06's Avatar
Agreed.
Old Feb 12, 2007 | 04:06 PM
2000GTP's Avatar
Originally Posted by seawolf06
Agreed.
It wouldn't hurt to check the condition of the oil. If the oil is milky, it might explain where that coolant has been going.
Old Mar 17, 2008 | 10:39 AM
SATANAZ666's Avatar
What happened
Hi, did anyone ever fix this problem?? Im having the same problem as the original poster.
Old Mar 17, 2008 | 10:59 AM
What has been done? Has any of the advice already given been followed?
Old Mar 17, 2008 | 11:09 AM
SATANAZ666's Avatar
Checked for trouble
Hi, thanks for replying. I have checked for:
Leaks
air in system
wiring etc...
Everything seems to be fine.
The temp gauge was fluctuating a bit last week when I took it out for the first time since Nov. But I didnt think it was serious.
Yesterday I look down at the gauge while ont he highway and its pegged at over 260!!!!!
I stopped let it sit for 30 minutes and when I started it up it was still pegged at 260!!!
But the car wasnt really hot.........weird!
can it just be stuck there??
Old Mar 17, 2008 | 12:32 PM
1997whitez28's Avatar
It's about there time
funny that more then 10 years since the Lt1 was out and I notice people are having the same problems with certain things. It is the temp sensor on the block. I changed mine and it runs good. I had the same problem. I guess this is the time when the sensors and gaskets go. damn my car is already 11 years old. Dont forget to do the sensor on the pump
Old Mar 17, 2008 | 01:20 PM
It could be the wire to the temp sensor in the head is grounded out.
Old Jun 4, 2008 | 10:40 AM
SATANAZ666's Avatar
Solution
IT WAS THE TMP SENSOR IN THE HEAD!
Thank you all !
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
