intake bolt stripped head
Old Jun 3, 2008 | 06:09 PM
jer4251's Avatar
went to torque my first intake bolt and it kept on spinning. never went past 50 lb/ft was suppose to be 71 lb/ft first pass then 35. im scared to do the rest.
dont know what to do.
Old Jun 3, 2008 | 06:19 PM
jer4251's Avatar
wow. guess i should have paind more attention. 71 lb/in not ft.
will i be alright with a missilg bolt. what should i do?
Old Jun 3, 2008 | 06:21 PM
cnorton's Avatar
Among the first things to do is re-check the 71 ft. lb. torque spec. A 3/8" steel bolt threading into soft aluminum at 71 ft. lbs is a recipe for disaster. (Just took a quick glance at Shoebox's torque matrix and it shows that the first stage should be at 71 in. lbs.)
The most logical solution at this point is to take the manifold off and inspect the damage. There may be a few threads left in the bottom of the hole that the bolt didn't reach. If there aren't enough threads left to guarantee a secure seal, repair will be necessary. Repair solutions include a thread insert or a helicoil and it may be necessary to remove the head in order to make sure that the new threads go in straight.
Good luck.
Old Jun 3, 2008 | 06:35 PM
lt1junkie's Avatar
Time for a helicoil
Old Jun 3, 2008 | 07:00 PM
Fei's Avatar
Fei
Don't feel bad man... I did the exact same thinga few years back. Just put in a heli coil and be done with it.
Old Jun 3, 2008 | 07:45 PM
Remove intake and install thread insert or heli-coil.
Old Jun 3, 2008 | 10:34 PM
jer4251's Avatar
how bad is it going to leak? it goes to about 20 lb/ft and thats it. its # 4 in the sequence.
Old Jun 3, 2008 | 11:42 PM
ssbowtie1's Avatar
No one is going to be able to give you an answer to how much it will leak. I wouldn't do it though. It could cause anything from leaking to warping of the manifold. Take it off and do it right, this isn't backyard mechanics.
G'luck.
Old Jun 3, 2008 | 11:58 PM
Don't mess around. Fix it.
Old Jun 4, 2008 | 12:02 AM
Jazsun's Avatar
Unless the bolt was in the back it's not gona leak, assuming you get some kind of pressure on it w/ a new threads.
Old Jun 4, 2008 | 05:14 AM
rskrause's Avatar
Moderator
You could use duct tape, but I recommend repairing the threads.
Rich
Old Jun 4, 2008 | 05:25 AM
CANTONRACER's Avatar
Last time I had my heads off I had every thread for the intake heli coiled...next time I will the exhaust side to.
Old Jun 4, 2008 | 12:42 PM
jer4251's Avatar
i do plan on swaping heads in the future. not sure how soon. but the stock heads arent staying on for very long. wasnt in the current budget.
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Feb 28, 2015 12:02 PM
MadMav
Feb 6, 2015 11:02 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
