Temp gauge maxing out when car shut off
Old May 31, 2011 | 11:52 PM
Black 97 SS's Avatar
Temp gauge maxing out when car shut off but works fine when car is running.
Any ideas? Bad sensor in head? electrical short?
Thanks,
Jason
Old Jun 2, 2011 | 10:19 AM
Re: Temp gauge maxing out when car shut off
any ideas?
Old Jun 2, 2011 | 02:38 PM
hairbear21's Avatar
I've seen that in older vehicles with analog guages. I would say that it's just heat soak from the pump not removing the hot water from the block, or an air pocket that's getting super-heated.
Old Jun 2, 2011 | 02:52 PM
bw_hunter's Avatar
It really has nothing to do with the type of gauge...the gauge is reading the actual temperature of the coolant. When the pump stops pumping, the block heats the water rapidly......
It's quite normal.
Old Jun 2, 2011 | 04:14 PM
The gauage will go all the way to the RED as soon as the key is off, but will read normal with the key on. The Gauge never did this till the engine swap. Its like the gauge is getting voltage somehow when the key is off. You can acutally watch the gauge move all the way over once you turn off the car and resume correct temp when the key is back on.
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
