temp gauge is bouncing!
Old Jul 21, 2008 | 09:15 AM
lovemyblackz28's Avatar
Had some work done to the car recently. Put in new gaskets, intake, exhaust, new wires, opti. I noticed now that the temperature gauge bounes up and down. It will be working fine and then it will just go all the way down as if the engine was cold. 3 minutes later it will go back up to the correct reading. Is something loose?
Old Jul 21, 2008 | 09:24 AM
mfb_lt1birdman's Avatar
Probably melting the wire/pigtail with your headers. The the sensor installs on the drivers side. Here is a picture courtesy of the wonderful shoebox http://shbox.com/1/temp_sensor2.jpg I did this twice. I ended up having to use some high temp marine heat shrink tubing then covered it with that reflective aluminum heat tape.
But check that area out for a melted wire or maybe the pig tail is just damaged or loose.
KYWes
Jun 14, 2022 06:52 AM
malikot02SS
Aug 15, 2015 01:11 PM
MikeWhitener
Aug 2, 2015 06:17 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Campbellb48
Jul 5, 2015 06:31 PM
