Teflon (PTFE) oil additives
Old Jul 9, 2007 | 03:51 PM
gohan's Avatar
Hi All
Has anybody tried, on a LT1 engine, one of those Teflon additives to add to the oil in order to lower the engine friction?
Old Jul 9, 2007 | 03:56 PM
speed_demon24's Avatar
oil addictives = scam
Old Jul 9, 2007 | 04:05 PM
gohan's Avatar
ok... I got the message
Old Jul 9, 2007 | 04:06 PM
mdacton's Avatar
search for it...Injuneer had some good info somewhere on it...
It has been found to be abrasive also....
Old Jul 9, 2007 | 04:51 PM
96capricemgr's Avatar
Most of the readily available ones are scams, there are a few good ones out there none containing PTFE though.
If you search the Web you will find a press statement by 3M about how Teflon is not good for many of the things it is used for. They saw it coming when they began selling licensing rights. Not sure if it specifically mentions liquid lubrication but does go into how it has to be heated to over 600F to bond to anything. That means pretty much anything on a store shelf that contains it, is using it as marketing and is of no real value.
Believe the FTC judgement against Slick50 would be good reading on the subject too.
Old Jul 9, 2007 | 05:22 PM
n2ceptor's Avatar
Poly Dyn TX7 part # 10001 quart; from what i have heard is pretty good...
Old Jul 9, 2007 | 05:37 PM
http://www.msgroup.org/TIP043.html
Old Jul 9, 2007 | 06:17 PM
FASTFATBOY's Avatar
What about the Lucas line of products, heavy duty trucks use the CRAP out of that stuff...we sell a load of that stuff where I work.
David
Old Jul 9, 2007 | 06:20 PM
mdacton's Avatar
David
I use that myself in my truck.....I use the oil and dsl. addative from them
Old Jul 9, 2007 | 08:06 PM
David
Lucas is perfect if you like foamy oil, best to skip it if you want oil to properly protect things.
Old Jul 10, 2007 | 01:31 AM
gohan's Avatar
Originally Posted by Injuneer
I have done some searches in google and I always found pages stating the same exact words as the above link.
I mean that to a person that is not expert in this matter it seems that everybody could be right and wrong at the same time because from one side there are claims from the manufacturers of those additives actually works and on the other side I find only the same article over and over stating that additives are really crap. None of them is actually linking any official source of their claims.
Old Jul 10, 2007 | 01:54 AM
Just buy good oils and don't worry about addictives.
Old Jul 10, 2007 | 02:28 AM
gohan's Avatar
Are you staying up late tonight?
Yeah, that would be the idea, but I was only trying to get a better overview about them: if there is something unclear I get really curious... I can't help it
Old Jul 10, 2007 | 06:22 PM
Try looking at pages 20-22 in this book:
High-Peformance Automotive Fuels & Fluids, Jeff Hartman, Motobook International, ISBN 0-7603-0054-2
Old Jul 11, 2007 | 04:37 AM
gohan's Avatar
I guess there is no way to read those 3 pages without buying the book, right?
