Tech Questions on my V6 Swap to a LT1
Old Feb 5, 2005 | 09:50 AM
WhiteboysZ28's Avatar
OK SO Im doing a V6 swap out with the 3.slow & inwith the new LTfast with a T56 trans. I have the engne Trans, wiring , new drive shaft , pretty much everyting , Now my questons.
Will the 3.4 with a 5 speed trans stock torsion bar interchange with the T56??
Will the hydrolics from the 5 speed work with the T56 ??
Also the wiring harness I have for the Lt1 was from an Automatic work with my T56 trans???
will the V6 radiator work with the Lt1???
Any help is appreciated here , Also if there is anything else you can think of I may need for this converson let me know.
Thank you guys.
JOSH
Old Feb 5, 2005 | 02:46 PM
GreenDemon's Avatar
Re: Tech Questions on my V6 Swap to a LT1
The wiring harness and the radiator should work. You'll need to do a little cutting and splicing to make some of the tranny connections work. You'll probably want to get a dual fan setup, the LT1 makes a tad more heat than a 3.4.
I doubt any of the other stuff will work.
Old Feb 5, 2005 | 06:03 PM
thanks I appreciate it
oldschool
Feb 9, 2016 09:21 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
