teach me hot to launch ET Streets ! M6 ?
Old Aug 16, 2004 | 11:27 PM
Mystic97Z's Avatar
mods in sig, car is a 97 lt1 6 speed with a spec stage 3 clutch, this is my 1st time with these. 26 x 10.5 mickey thompson et streets. i really want to hit 12's, how do i launch? with my street tires i always had to do a really quick/aggressive street start, and did a best 60' of 2.1
w/ this cam setup, it will bog a big, im gonna need to keep the rpms up when i launch wont i? thanks for the help.
-Jason
Old Aug 16, 2004 | 11:35 PM
Poik's Avatar
Re: teach me hot to launch ET Streets ! M6 ?
Spec stage 3, et streets, and the 10 bolt? Ouch! Hope you don't blow your rearend on the track!
Old Aug 16, 2004 | 11:53 PM
bski224's Avatar
well being that you have stock 12 bolt and Slicks= BOOM to rear hopefully not. If you wanna launch with your tires (you have good clutch) What i do is run about 10-12 PSI in tires and dump clutch at or around 4,000, Go through water box and do a DECENT BURNOUT, dont be afraid to heat those fu*%s up. You can go 10 PSI but be careful it will get a little squirly on ya. GOOD LUCK DUDE!!!
Old Aug 17, 2004 | 12:32 AM
RiceETR96's Avatar
It should hold for a few launches, I've seen plenty of people do 4500-6000 RPM launches on stock 10 bolts. If you're just looking to run a 12 to say you can, and are willing to rixk blowing the pinion to pieces.... hols it at 4500-5000 rpms and dump the clutch, stab the gas & hold on.
By the way I've seen that net some low 1.70's never tried it over 5 or six times though.
Old Aug 17, 2004 | 01:07 AM
RED95LT1Z28's Avatar
Yeah 10 bolt and et streets with that much power esp. going through a M6...i wish you luck....but like he said i run mine at 10 psi and i just heat em up till they really start to smoke and go....but my buddy with his M6 doesn't hold the revs...when the lights start to drop he just starts to rev the car and snap the clutch....pulls 1.6 60'
Old Aug 17, 2004 | 11:46 AM
Mystic97Z's Avatar
i've talked to people who pull 1.60's on their stock rear end time after time. but then again i have heard of people who do it like 2 times and it breaks. ??
Old Aug 17, 2004 | 11:53 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Dang man and i am worried about breakin mine with DR's.... Good luck!
Chris
Old Aug 24, 2004 | 12:05 AM
ford's Avatar
I should be launching on ET streets, 150 shot, M6 and every bolt-on around. We will see how long it holds.
Old Aug 24, 2004 | 12:12 AM
96ta(nick)'s Avatar
Rev it up drop the clutch and listen to it go BOOM! Clank Clack clack....
I broke my 10bolt on street tires
12 bolt coming next week
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Countryboychevy
Jun 13, 2015 02:49 PM
Boss002
May 20, 2015 12:55 PM
