TEA 220cc trickflows
Old Jun 13, 2007 | 04:54 PM
95fbformula's Avatar
Are these heads to big for a 355. i was thinking about using them and having them milled to 56cc chambers. with a 0 decked block and my pistons and a .038 gasket they make about 11.5.1 SCR but is the port to big for a street driven car.
Old Jun 13, 2007 | 04:59 PM
Wild1's Avatar
Port velocity is important on a street engine. If your running a 396, you could probably get away with it. My edge is that it is somewhat too big for a 355.
Old Jun 13, 2007 | 05:02 PM
Thats what i was thinking i probably will go with the 200cc
Old Jun 13, 2007 | 05:12 PM
FASTFATBOY's Avatar
No, they are not too big, cam it right, 12 to 1 compression and hold it in the street.
David
Old Jun 13, 2007 | 05:18 PM
marshall93z's Avatar
Agreed!
Old Jun 13, 2007 | 06:01 PM
Quickz1670's Avatar
Your quench is good . Shoot for a DRC of 8.8, 8.9 and like stated above 12 scr. 373s and you'll manage on the street.
Old Jun 13, 2007 | 08:04 PM
what could i do to get the 12 to 1 as of now with the 0 decked block, -5cc flattops, .038 quench, and 56cc chambers thats as low as the trickflows can go. i get 11 to 5
Old Jun 13, 2007 | 09:58 PM
Wild1's Avatar
You are correct with 11.5:1 SCR. What are your cam specs and I'll help with the DCR.
Old Jun 13, 2007 | 10:30 PM
I haven't had one spec'd yet i plan on a custom as soon as i have my heads done so it will match properly.
Old Jun 13, 2007 | 10:36 PM
Quickz1670's Avatar
Looking at the flow chart the 220cc heads are flowed on a 4.125 bore whereas the 200cc head is flowed on a 4.03 bore. Looking at both charts the 200 have better mid lift flow #s on a smaller fixture. The 200 would be better for a street driven car. I should've looked at this before posting. Anyone have results from either one of these heads?
Old Jun 13, 2007 | 10:41 PM
Thats what I was thinking i wanted to know about the 220cc is that they are about 100 more. i probably will go with the 200s though that way the 11.5 compression should be enough and if i want to go bigger stoker or fi i can just have them ported somemore.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
SPANKY LS1
Aug 28, 2003 10:00 PM
