TBI Fuel Pump for carb swap
Old Jun 5, 2022 | 12:29 PM
94lt1gobrrr's Avatar
I am in the midst of converting my trashed efi to a carb. What I want to do is run lines from the fuel pump to a pressure regulator with return so I can use the carb. However the stock pump is 40 something psi and I only need 6.
my solution was putting a fuel pump meant for a TBI 350 which makes only 12 psi in the fuel tank.
would the lines fit to that pump? And would it bolt into the tank is my question
Or is there a better way to run low fuel pressure for a carb like an in line fuel pump drawing through the stock pump
User56898
Classic Engine Tech
Feb 25, 2006 06:31 PM
whitelightning782
Classic Engine Tech
May 25, 2005 05:46 PM
redsick93lt1
3rd Gen / L98 Engine Tech
Feb 20, 2005 11:32 AM
Rice Killer87
20
Dec 25, 2003 10:52 PM
Fusiondog
Jun 17, 2003 08:31 PM
