TB Gasket question??
Old May 26, 2005 | 10:43 AM
94Zpower's Avatar
This past weekend I had a N20 back fire through the intake and the car is ok and runs fine if I unplug the MAF so I naturally thought the Maf was blown out, I got a new one and same problem,
So I started listening under the hood and noticed that the TB plate for my N20 seemed to have a leak between the TB and the intake, so my question is ....would a leaky TB gasket cause the car to run and Idle like Cr*p???
Thanks!
Old May 26, 2005 | 11:03 AM
Re: TB Gasket question??
Sure.... that's a vacuum leak. It means the MAF isn't measuring the correct air flow, forcing the PCM to compensate using the long term fuel corrections. It makes sense that unplugging the MAF would help, since the PCM defaults to speed-density, and speed density would compensate because of the change to MAP caused by the vacuum leak.
Not to say you didn't damage anything else.... did you check the MAP sensor, look for bent throttle blades, check to insure the IAT sensor is still there, check to make sure the elbow wasn't blown off the bottom of the TB where you can't see it.... etc.?
Sergio
Jan 27, 2016 04:27 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
