TB bypass question
TB bypass question
I'm going to do the coolant bypass when I get my new TB and I just wanted to know what kind of temps you need to cause any problems with it afterwards. Since it's winter here now it can get down to single digits overnight sometimes and I didn't know if that would cause any problems. I have to start it up early in the morning most days to get to school. Will I be fine doing that and letting it warm up, or should I avoid driving it when the temps get that low?
I've heard of people who have done this in areas where it gets to the negative temps (actual temperature and not wind chill... that's damn cold for a Florida boy!
). They said they had no problems.
I'd really like to know why the GM engineers thought this necessary because I haven't seen/heard of a case where it has been actually *needed*? There must be a reason but I have yet to read a good explanation.
). They said they had no problems.I'd really like to know why the GM engineers thought this necessary because I haven't seen/heard of a case where it has been actually *needed*? There must be a reason but I have yet to read a good explanation.
On start up your coolant is just as cold as you TB so theres no advantage there. The TB should still warm up after that just because of engine heat. I don't see why you need the extra heat provided by the coolant.
Originally Posted by the GM Factory Service Manual
To prevent throttle valve icing during cold weather operation, engine coolant is directed through the coolant cavity on the bottom of the throttle body.
lbrowne
Nov 13, 2011 04:25 PM
