TB Bypass, to do or not to do?
Old Jan 11, 2004 | 06:22 PM
FastWhiteTA's Avatar
My engine runs pretty cool w/ the 160 thermostat, I'm trying to get some input on what the advantages would be of bypassing the TB coolant. Is it true that when the engine and TB is heat soaked having the TB bypass still makes more power? For example, what about here in Texas in the summers when it's VERY hot, will having the TB bypass be a bad thing? With the temperatures of the engine, it seems the TB would absorb a lot of the heat from the intake and engine, and hurt power. Is that a correct assumption or am I way off? I've seen dyno gains of up to 6 rhwp on a heat soaked engine w/ TB bypass, seems like that can't hurt ya huh?
Old Jan 11, 2004 | 06:31 PM
gb95zconv's Avatar
I dont know about hp gains but it sure does make it easier to take the TB off for cleaning.......its very easy to do so why not do it.....no down side to it.
Old Jan 11, 2004 | 06:49 PM
MentalCaseOne's Avatar
My car used to feel sluggish as soon as it was heat soaked... I always loved the "first thing in the morning" power feeling but as soon as noon would kick in... my car was a turkey. I did the Mod and whoah... I did not gain HP per say... Actually it kept the car from loosing power.
so I have the same power as if I cranck her first thing in the morning but all day and night ... So in my opinion it keeps your from loosing power. I would say 7hp recovered is a good estimate.
Marvin
Old Jan 11, 2004 | 07:08 PM
billsbird's Avatar
....yeah, it doesn't add H.P, it keeps you from losing it. I think the reason the factory puts it on there has something to do with it helping in cold weather... Bill...
Old Jan 11, 2004 | 07:22 PM
gamecockfan04's Avatar
The TB bypass is actually dyno tested to add between 6-7hp.
Old Jan 11, 2004 | 07:33 PM
billsbird's Avatar
...hummm, wow, I didn't know that! Thank you for the info
Old Jan 11, 2004 | 07:39 PM
Old Jan 11, 2004 | 07:59 PM
Zack's Avatar
if you are prone to having bad luck, like me I wouldnt bother.Lets just say a month ago or so I did the TB bypass. NOw im tearing apart the top end to replace head gaskets(not an actual result of the bypass though)
Old Jan 11, 2004 | 08:10 PM
billsbird's Avatar
...very interesting! Thanks for putting up the dyno sheet. I know I did the by-pass on my '94 Firebird, wasn't sure if it helped or not.... Bill...
Old Jan 11, 2004 | 09:31 PM
Josh-'04 GTO's Avatar
Here's another dyno chart that pretty much says the same thing. Definitely a good "free" mod.
http://www.ws6.com/mod-8.htm
Old Jan 11, 2004 | 11:25 PM
Awesome, I'll do it this week, another 5-6 rwhp is ALWAYS welcome!! Thanks for the dyno sheets guys!
Old Jan 11, 2004 | 11:35 PM
Seal's Avatar
yeah, 5-6 hp is hard to notice i might do it too when i'm cleaning my tb
Old Jan 11, 2004 | 11:39 PM
billsbird's Avatar
....yeah Seal you should do it. Anything that I can do in 5 minutes has GOT to be easy.... ;} Bill...
Old Jan 12, 2004 | 03:59 AM
neat's Avatar
After my cam swap, I thought I was possibly sukcing in coolant, so I did it. It's easy, and might give you a couple ponies.
Old Jan 12, 2004 | 08:27 AM
Eliminator's Avatar
I did it to mine cant hurt.
