tb bypass on a 93 z
Old Aug 4, 2003 | 06:00 AM
hot936spd's Avatar
tb bypass on a 93 z
how do you do one on a 93 z. and is it worth it, would it hurt anything?
Old Aug 4, 2003 | 08:31 AM
Fastbird93's Avatar
Won't hurt anything, and it's a very simple thing to do. All you need is a single plastic connector, I believe it's a 3/8" size, two small band clamps, and a couple of small plastic caps. You unplug the two coolant hoses from the throttlebody, AFTER draining a little coolan so as to not make a mess, put a small cap on the two openings on the throttlebody, connect the two lines via the plastic connector, tighten the band clamps, and drive happy!
Old Aug 4, 2003 | 08:21 PM
Bud M's Avatar
Be sure to put some towels around where you are working so your opti stays dry when you spill coolant from the hoses when you pull them off the throttle body.
Old Aug 4, 2003 | 09:19 PM
brandboZ28's Avatar
I broke the clamps that hold the hoses on the tb so I just cut the hoses as close as I could to the tb and it worked fine. Doesnt look the greatest but it works Also as Bud said, use a few towels so you dont get your opti
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
