TB Bypass 93 LT1
Old Jan 6, 2004 | 03:16 PM
webbicle's Avatar
TB Bypass 93 LT1
I'm sure this is posted in some detail about 10 other times, but I can't find info specifically for a 93 (everything seems to be a bit different ).
I'm sure someone can explain in one sentence how this is most easily done.
Apologies and thanks in advance!!!
Old Jan 6, 2004 | 06:11 PM
Mtrhds94Z's Avatar
93-4 you need a 3/8" brass hose connector[ hardware store item] and 2 hose clamps..
Take both coolant hoses off the TB, and connect with the hose... [2 3/8" vacuum caps are optional to cover the 2 outlets you took the hoses off of]
95-7 don't need that connector but 93-4 you do..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
brandboZ28
Jan 31, 2003 06:19 PM
kclarson
Aug 22, 2002 04:04 PM
Skull Leader
Aug 10, 2002 11:01 AM
