tb bypass?
Old Jul 25, 2004 | 10:30 AM
camzaro28's Avatar
tb bypass?
i went to shoebox's site and seen how it is done, but if i dont cap the two pipes will it cause a problem?
Old Jul 25, 2004 | 10:32 AM
Red96Lt1's Avatar
Re: tb bypass?
I don't have it capped on my TB. It's just to keep dirt out of there if you ever want to hook it back up again.
Old Jul 25, 2004 | 10:33 AM
camzaro28's Avatar
Re: tb bypass?
thanks red96 that was the quickest reply i have ever got. thansk again. damn i love this site
Old Jul 25, 2004 | 10:36 AM
ibanez6rg's Avatar
Re: tb bypass?
Yulp, you'll be fine. Just might want to make sure all of the coolant is out of the TB.
Old Jul 25, 2004 | 11:02 AM
camzaro28's Avatar
Re: tb bypass?
ibane are u referring to the coolant dripping out of the lh side of tb? and the 90 elbow i just cant get to. all of my tools are on the jobsite so i am going to have to go to sears or somthing to get some new ones. i thought this was going to be easy
Old Jul 25, 2004 | 11:07 AM
RamAir95TA's Avatar
Re: tb bypass?
Once the lines are disconnected, there's really nothing to worry about. I plugged them just for the clean look.
Old Jul 25, 2004 | 01:08 PM
camzaro28's Avatar
Re: tb bypass?
where do u get these plugs? and what are they called? and when i take the hose that comes from the radiator off fluid comes out of the tb. am i supposed to let all that drain out?
Old Jul 25, 2004 | 02:07 PM
camzaro28's Avatar
Re: tb bypass?
finished!!!!!!!! damn i never thought i was going to finish that. tha tlil elbow was a pita
Old Jul 25, 2004 | 02:23 PM
darthrug's Avatar
Re: tb bypass?
how did you get that lh hose off?
Old Jul 25, 2004 | 03:36 PM
Bow94z's Avatar
Re: tb bypass?
3/8" caps will plug the holes.! during cold winter months if you still drive ur F-body i would connect the coolant hoses back on the TB to cause it from freezeing. Its only a good mod in the summer time!
Old Jul 25, 2004 | 04:06 PM
zoso1959's Avatar
Question Re: tb bypass?
I don't know how true this statement is, i've heard that gm did for possible lawsuit cases againist, i live here in chicago and never had a probrlm with my
tb blades freezing,
this might help if you have this car in canda now,
zoso1959
Old Jul 25, 2004 | 04:54 PM
Ryan's LT1's Avatar
Re: tb bypass?
Depends on how cold it gets in the winter, if it gets below freezing where you live they might freeze, but anything over that and your TB blades won't freeze.
Old Jul 25, 2004 | 06:35 PM
Getsome17's Avatar
Re: tb bypass?
I did the TB bypass 2 winters ago and I haven't had any problems at all.
Old Jul 25, 2004 | 06:41 PM
camzaro28's Avatar
Re: tb bypass?
well i am in florida, we dont see freezing temps but posssibly a few times out of the winter!
how did you get that lh hose off? if u are talking abou teh lil 90 degree elbow, the two lil clamps that were on it were upside down and the most pita thing to get to. i took the alternator brackets off, unpluuged all the wire harness deals going on, ( jsut so i could get a good look at it , and not rip them apart while going crazy trying to tear it apart!) then kinda twisted them a lil to break them loose then got a flathead screwdriver and pryed them down! not as easy as i thought! have fun if u still havent finised lol!
Old Jul 25, 2004 | 07:38 PM
ibanez6rg's Avatar
Re: tb bypass?
If it gets cold enough to freeze your TB blades, how on a cold startup is coolant going to unfreeze them? They don't need to be put back on for winter.
