taylor wires?
Old Mar 23, 2006 | 12:18 PM
runninfromthelaw's Avatar
taylor wires?
I was going to order some taylors off of summit and I'm lost theres so many part #s but they all say the same thing.They change in price also for the same wires it looks like.Also they have a listing for 8.2 wires is this a new wire are they any good.Just would like to know what to order and whats the best for my buck.this is for my 95
Old Mar 23, 2006 | 12:19 PM
buzz12586's Avatar
Re: taylor wires?
I have the same question. I will be doing wires and plugs soon on my 95. I don't have headers yet and probably won't for a while. Whats the best to go with???
Old Mar 23, 2006 | 12:35 PM
robwin95z's Avatar
Re: taylor wires?
i just purchased this exact set of 8.2mm's for my 95z. they seem to really be of good quality and thick too. i'm installing mine this weekend right after i get that damn passenger side header in.
Old Mar 23, 2006 | 12:37 PM
robwin95z's Avatar
Re: taylor wires?
o yeah, i believe the 8.2's come only in the "taylor thundervolts" in red, blue and black.
Old Mar 23, 2006 | 12:41 PM
buzz12586's Avatar
Re: taylor wires?
Are they precut and assembled or do you have to make them yourself?
Old Mar 23, 2006 | 01:42 PM
robwin95z's Avatar
Re: taylor wires?
they come precut to stock lengths. just pull em' out of the box and install.
Old Mar 23, 2006 | 02:03 PM
CrazySJ95Z28's Avatar
Re: taylor wires?
MSD has 2 sets of Super Conductor wires that they make for the LT1s for Camaros/Formulas(TA), MSD-32149 is a set of premade wires for 96-97 cars that will work to run in the stock locations, they also have the set MSD-32129 which has the LT1 distributor boots on one end and they are not premade, so you have to cut them and crimp the terminal on yourself. The 32129s are good if you want to route the wires over the valve cover. Both sets will actually work on all years 93-97 but, the difference is that there is a coil design change from 95-96. 95 and older cars need the spark plug style boot on one end for the coil, 96 and 97 cars need the optispark style boot on both ends. The 32149s have the correct coil wire for 96-97 cars, I don't remember about the 32129s, they may or may not come with both styles of boots for the coil wire.
Old Mar 23, 2006 | 03:43 PM
2000GTP's Avatar
Re: taylor wires?
Here is the part number for the stock length Taylor wires that I ordered for my car from Summit: TAY-74239
The kit also came with two ignition coil wires,(one for each style), so the kit is compatible with all 93-97 LT1s.
Old Mar 23, 2006 | 03:44 PM
Re: taylor wires?
I see on the site there is a universal set if i get them will they be the ones i can make to go over the valve covers.I have long tube headers so i have problems with wires burning.
Old Mar 23, 2006 | 03:45 PM
Re: taylor wires?
also the 8.2s are a few dollors more are they any better or is it just sheilding
Old Mar 23, 2006 | 03:46 PM
2000GTP's Avatar
Re: taylor wires?
If you have long tubes, then I would go with the set that will allow you to cut and make your own. Otherwise, you will have to be careful using stock length wires as they have many catch spots on the headers.
Old Mar 23, 2006 | 04:00 PM
buzz12586's Avatar
Re: taylor wires?
The application for that set just says 96-97. You sure it will work with a 95???
Old Mar 23, 2006 | 04:09 PM
2000GTP's Avatar
Re: taylor wires?
Maybe Taylor changed things up and is only including the one coil wire specific to your application? Looking closely at the picture, I count only 9 wires so they definitely are not giving the two styles of wires. If thats the case, then you would just have to get the set specific to your year.
Old Mar 23, 2006 | 04:44 PM
Re: taylor wires?
Is there any special tool to build the wires or is it really easy.also has anybody done this if so what part # is best or just get the universal kit.
Old Mar 23, 2006 | 05:03 PM
Loadre's Avatar
Re: taylor wires?
Taylor wires suck ***. Go with MSD or Accel.
CobraEatr
Jul 24, 2004 11:37 AM
Burn_Out
Aug 18, 2002 08:49 AM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
