Taylor OVC and SLP shorties
Old Aug 3, 2003 | 10:48 PM
Dave19yz28's Avatar
Exactly what the subject says...im gettin a set of SLP shorty headers..anyone have any problems using OVC wires...or should i stay with stock? Thanks
Old Aug 3, 2003 | 11:28 PM
magius231's Avatar
did it on mine, works great. I used Bosch platinum plugs which are a little shorter than normal, and with no heat sleeve I have yet to burn a wire.
Old Aug 3, 2003 | 11:37 PM
Dave19yz28's Avatar
awesome...thanks for the reply
Old Aug 4, 2003 | 06:28 PM
TimChiaretto's Avatar
Be aware, the car that magius231 did this on is a single cat machine. I believe your car is dual cat and that is a totally different set of headers. I ran my wires through the stock locations and haven't had any problems.
Old Aug 4, 2003 | 06:58 PM
colorchange96's Avatar
you dont need the OVC kit. to me it is more of a pain than its worth. just buy some good wires like ACCEL 9000 header wires and run them through the motor mount holes and then up to each plug. on the driver side you can tuck 5 and 7 real close to the block and zip tie it and youll be fine there.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
