Video clips after the headers
Old Aug 4, 2003 | 10:22 AM
Fast96WS6's Avatar
Thought I'd share some clips of my car after the headers were installed.
Make sure you "Right Click" and "Save Target As" to download them
Open Headers
Idle
Rev
Tell me what you think
Old Aug 4, 2003 | 10:25 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i think 300 pages of this:
Z2耺d IS41 ҏ uΑ{5VmyxJBc.B~(^Y L F蔑?_5TЀ#5P^-" J#?g"@!s|z:h Mby@V|TTzGZBU 탤dS]'N<`.A8/b_2p8 8`@cw0:HۃS{' 0#9%z\ĤTj%#iDf4 0$+ uI@ʖ-i8<%kŋePn-:@q8)s:\fu=1xG)-a@6d_b|6p%J"N4_V>?` O 5K<&'1r[ vul&LL5?DBtc^?5SH [POl`~Ѐ_ae:zFү'∽Pg@|  _)Zv >xJ7K^ K@#%_MZaL`  ,Dݙg`fŒ:a%; &+3pFz~i`T Bb)V.f"rgB@ I'r!?Ƈub`8 Mg0V^| $xf$+"9sPj62~0)#:qYF (b jhP( X;Wd JUA.LP9q1*?!}3;%#tĢH@*l~ 0(@B`@H& $[ARңpy ԜwSXBVǘ^敔i;.NϷoEdKEe ( 5M|?/ӄG*(Be(*Ec#pjC 0p:@OY߄/"x LG v_{8F FJSCM8 Fp*8X!ըr)*Gh! 5,?Jq /Ng(ńr֦J {
sounds very throaty
Old Aug 4, 2003 | 10:26 AM
Fast96WS6's Avatar
My friend was having problems, but when he right clicked and saved target as, it worked fine. Also, you can copy the URL in Windows Media Player and it should work as a stream.
Old Aug 4, 2003 | 11:25 AM
Black_Z28's Avatar
sounds very throaty
Are you using Mozilla? That's maybe why you're getting that problem. It doesn't stream WMVs.
Old Aug 4, 2003 | 12:33 PM
calfirebird's Avatar
i got the same thing
Old Aug 4, 2003 | 02:21 PM
lbrowne's Avatar
Doesn't work for me either, right click tries to save it as a .html file.
I CRACKED up when I read the first reply to this HAHAHHAHHA
Old Aug 4, 2003 | 02:56 PM
Black_Z28's Avatar
Just delete the html part when you choose to save the file. It worked fine for me.
Old Aug 4, 2003 | 03:18 PM
Fast96WS6's Avatar
I changed all of the files to MPG's. Hopefully it works better. My firends have been able to stream them in WMP. But you should be able to right click and save target as
Old Aug 4, 2003 | 03:46 PM
mineralwater's Avatar
Is that a collector's edition trans am I see next to your fbody? Show us some vids of that!
Nice videos, btw. I didn't know the hotcam could sound so lopey for its size - do you have tuning?
oh, and you might want to trim down that teensy sig of yours. :P
Old Aug 4, 2003 | 03:49 PM
96_Camaro_B4C's Avatar
Re: Video clips after the headers
Originally posted by Fast96WS6
1996 Firebird Formula WS6 (# 2409)
My 96 Formula WS6
Modified Ram Air w/ K+N
TB Coolant Bypass
Holley Air Foil
Jet Hot Long Tube Headers
Custom 3" Y-pipe
Carsound High Flow Cats
SLP "Loudmouth" exhaust
Pro 5.0 Shifter
SPEC Stage 2 Clutch
SPEC Lightweight Aluminum Flywheel
3.73 Motive Diff Gears
Hypertech 160 Thermostat
LT4 Knock Module
MSD 6AL Ignition
MSD 8.5mm Plug Wires
NGK TR55 Spark Plugs
1LE Tranny Mount
Harlan Shift Light
LT4 Hotcam Kit (LT4 Hotcam, 1.6 RR's, LT4 Valve Springs)
LT4 HD Timing chain
317 RWHP
322 RWTQ
(stock programming and stock exhuast manifolds)
Holy long signature, Batman! Just so you know, there is a 5 line sig rule here.
Old Aug 4, 2003 | 03:56 PM
Fast96WS6's Avatar
Hope thats better
Old Aug 4, 2003 | 04:55 PM
SantaCruz163's Avatar
Sounds real bad ***. I give it You live in CT as well? You ever go out to the pike? You a member of CTFBA?
Old Aug 4, 2003 | 05:45 PM
SSlammedlt-4's Avatar
Screw the muffs, Drive it like that
Sounds really good for the Hot cam
Old Aug 4, 2003 | 07:06 PM
Fast96WS6's Avatar
Haha, thanks for taking a look. I dont have tuning, just the mods in my sig.
Yeah thats a CE TA next to mine. One of F-bodies in my driveway regularly. I live with a CE and a Black 02 TA WS6 owner.
I just moved to Stratford CT in May, and I go to the pike every weekend I get. I'm not in CTFBA, but I was at the Dyno Day at East Side Performance.
NewsBot
Mar 13, 2015 07:15 AM
NewsBot
Feb 26, 2015 02:10 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 21, 2015 06:10 PM
