Taylor OTVC
Old Apr 13, 2006 | 03:51 AM
hsyr's Avatar
Taylor OTVC
Hey everyone. I just got my talor otcv wire set from thunderracing and I was just wondering if these wires are already cut to length? I just opened the box and will be installing them tomorrow but I want to make sure before I hack them up since I have to put opti ends on them.
Old Apr 13, 2006 | 06:02 AM
sssalah's Avatar
Re: Taylor OTVC
If they were cut to length then I guess they should have the opti ends installed. Have fun installing the opti ends.
Old Apr 13, 2006 | 06:50 AM
97FormulaWS-6's Avatar
Re: Taylor OTVC
They are not cut to length; you need to route them, then cut them to length.
Old Apr 13, 2006 | 07:21 AM
69z-28's Avatar
Re: Taylor OTVC
FUGG ME!!! these sucked when i put my headers on.lol. sorry but they are a huge PITA the first time you do it. good luck
Old Apr 13, 2006 | 07:46 AM
x Wild Bill x's Avatar
Re: Taylor OTVC
Yeah have fun with those, did you get the ones that bolt to the valve covers or the ones that attach to the side of the heads? The reason I ask, is I got the ones that attach to the side of the heads and they are a PITA to install! I had to bend and file them just to get em on. And yes you have to cut the wires, the kit should have came with a crimping/stripping tool. It isn't all that hard, put some liquid dish soap on the wires and the opti ends will slide on soooooo much easier!
Have fun with em,
Bill
Old Apr 13, 2006 | 01:35 PM
hsyr's Avatar
Re: Taylor OTVC
Thanx for the help guys. I have the set that go into the valve cover, not the side mounts. Is it hard crimping on the opti ends on just putting on the boots?
Old Apr 13, 2006 | 02:08 PM
FastZinTennessee's Avatar
Re: Taylor OTVC
You have to cut them to fit. Measure twice, cut once.
Old Apr 13, 2006 | 03:00 PM
Re: Taylor OTVC
It is easy crimping them on, the hard part is sliding on the boots. I hooked mine up to the spark plugs, then ran them through the holders and made sure it was going to the right spot on the opti and cut them. Then I crimped on the opti end and then slid on the boot. Putting on the boot for the coil with the 90* was actually alot easier then the opti ones!
Good luck,
Bill
RUENUF
Mar 13, 2016 03:37 PM
Bobczar
Oct 23, 2015 11:22 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
