Taking out webing in Stock Valve Covers
Old Jun 28, 2007 | 07:08 PM
jclt12003's Avatar
Hey guys can i just take my angle grinder to the webing in my stock valve covers. Are they really used for that much support. I am running different rockers and am going to run into clearance problems. I searched for a few pics but all the links i go turned up dead. Thanks for the info
Jason
Old Jun 28, 2007 | 08:31 PM
1redTA's Avatar
re
you can use anything to cut the cover support FYI don't try to rip out any of the supports with pliers you can rip the covers ask me how I know
Old Jun 28, 2007 | 09:16 PM
lethal93ta's Avatar
I just used a cut off wheel, you dont need to take the center out where the bolt goes, just the piece between there and the cover.
Old Jun 28, 2007 | 09:28 PM
stereomandan's Avatar
I didn't have to remove mine to get the Pro Magnums in. I just needed to bend the ears straight for clearance.
Dan
Old Jun 28, 2007 | 09:31 PM
JAKEJR's Avatar
Check Golen engines site. Just do a Google search to find the site.
He posted a pic showing where to cut the LT covers. I believe the pic is in the Tech section down near the bottom of the page.
Jake
Old Jun 28, 2007 | 10:13 PM
The webs help spread the bolt loads to the perimeter of the covers, to help the gaskets seal better. If you have to cut anything out, don't take any more than you have to.
Old Jun 28, 2007 | 11:03 PM
speed_demon24's Avatar
Dan
What he said.
Old Jun 29, 2007 | 09:13 AM
JAKEJR's Avatar
Some clear and some don't.
I just ordered a new set of taller covers because my stock composite covers won't clear the poly locks on my 1.7 RRs.
I tried grinding one of the covers enough to clear and only ended up with a nice, nickel size hole in one of the covers. Now I've got to modify the A/C -Alternator brace to clear the new, taller covers.
"If it ain't one thing it's another".
Jake
Old Jun 29, 2007 | 09:45 AM
JP95ZM6's Avatar
Bending is probably better but tedious. I uised tinsnips to cut mine, one side of the supports only. 5 min.
Old Jun 29, 2007 | 11:05 AM
lethal93ta's Avatar
ya I only cut one side of mine, the pro mags were rubbing on mine, then I bought a set of billet alu covers and thos clear fine.
Old Jun 29, 2007 | 11:20 AM
buzz12586's Avatar
Yea I only had to cut one side of mine. The side closest the the intake manifold. I left the other side alone.
Old Jun 29, 2007 | 11:21 AM
It only took me 2 minutes to do both valve covers, I don't think that qualifies as tedious.
Old Jun 29, 2007 | 11:52 AM
The Engineer's Avatar
The Crane Gold Race S/A RRs fit without removing the web-bracing.
WD
Old Jul 1, 2007 | 12:03 PM
JP95ZM6's Avatar
Were you just flattening out the formed beads? I tried that a few times first, and had to work each bead a couple of minutes and still couldn't get them flat enough to clear. Maybe I just need bigger pliers. Anyway, you must have a better technique than I did. Share it?
Old Jul 1, 2007 | 12:11 PM
Yep, I just used vice grips and clamped them down and released then moved down the the brace until it was all flat then moved onto the next brace, they fit on my first try.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
