Taking Engine Out from Bottom But have a question
Old Nov 26, 2006 | 07:11 PM
95Blackhawk's Avatar
Actually 4. The writeups I have found online regarding taking out the LT1 show differently than what I think:
1. Do you have to remove the PS reservoir? It looks as if just removing the lines from the reservoir is enough.
2. Why take out the A/C dryer? Writeups show this but my best conclusion is to disconnect the opposite tube at the point of entry into the dash.
3. I see no reason to take out the ABS module. everything I have see says take it out but I don't see it as being in the way if you bend the brake lines a bit.
4. Steering linkage, can you just disconnect on the side of the steering wheel or do you really need to take out the linkage before dropping the engine? It would see just disconnecting one side would be enough.
Thanks all,
Ben
Old Nov 26, 2006 | 07:16 PM
wrd1972's Avatar
No, remove the the high and low pressure hoses at the rack.
I just unbolted the entire accessory mount bracket and suspended it without losing an freon (r* whatever)
Pop the two brake lines loose at the ABS module, this is a big time PITA.
Remove the small intermediate shaft just above the rack, just two bolt and easy as hell
Thanks all,
Ben
comments above
Old Nov 26, 2006 | 07:21 PM
cjmatt's Avatar
im pretty sure we left my entire power steering system hooked up, just unhooked the reservoir from the body and set it ontop of the motor
Old Nov 26, 2006 | 07:26 PM
klrz28's Avatar
bottom removal
leave the a/c pump in the body of the car and unhook the power steering lines and unhook the abs lines and leave the abs on the car any questions write me back ill help ya out its pretty easy really. out the bottom is the way to go
Old Nov 27, 2006 | 06:54 AM
Thanks all. These responses are giving me new directions.
Final question: I see a writeup where they strap the LCA so it does not fall down. is this important?
Ben
Old Nov 27, 2006 | 08:45 AM
jjminch's Avatar
Nice numbers you got there. Since your local, by chance do you want to custom tune my car?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Darth Xed
Jul 1, 2002 03:22 PM
