Taking apart a stock throttle body.
Re: Taking apart a stock throttle body.
You must cut certin parts of the throttle body to get the throttle shaft and blades out without damaging them.
The blades must be an elliptical shape because the do not set in the bore at a 90 degree angle. If you make the blades a round circle you will have an excessive amount of gap between the blades and bores. How do you plan on boring it?
