Taking apart electrical connectors
Old Nov 9, 2003 | 06:43 PM
kevmor99's Avatar
How do you take apart the electrical connectors, like the IAT or IAC connectors? I "probed" around w/ a safety pin but no clips were releasing
Old Nov 9, 2003 | 10:24 PM
You carefully bend back the catch on the connector until it clears a small tab (you can see it pretty clearly in the pic) on whatever it is coming off of. If you get too aggressive with a connector that has seen a lot of heat or is old, you can snap it off (so be nice). Give it a wiggle and it should come free. Never pull on the wires.
Old Nov 9, 2003 | 10:41 PM
kevmor99's Avatar
Oh, I mean removing the wires from the plug. I was able to do it to the temp. sensor in the head by pushing a pin into the little slot above each wire female terminal, it released the clip inside the plug and I easily pulled out the wires w/ the female terminals on them.
Old Nov 9, 2003 | 10:43 PM
blueirocz-28's Avatar
go to radioshack and buy the lil terminal tools for it. makes life realllly easy, if anything else, get a smallll screwdriver or pick and press the lil catches on the metal pins in and it should slide out.
Old Nov 9, 2003 | 10:55 PM
I guess I feel stupid. Seems like there have been some real basic questions around here lately, though.
Tools like mentioned or jewelers screwdrivers. Some multiple wire connectors have a "cap" on the back that should be removed first. Be careful, because you can easily break the "lock tang" on an individual terminal.
Old Nov 10, 2003 | 05:53 AM
Mtrhds94Z's Avatar
I ghetto rigged a 'pin tool' from a section of an old telescopic antenna off an old radio.. one of the sections was just the right diameter inside...
You might try something like that..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
squarehead
Jan 15, 2015 07:02 PM
Darth Xed
Jul 1, 2002 03:22 PM
