takes a while to start my car
Old Apr 5, 2005 | 06:20 PM
  #16
crazy_jackalope's Avatar
Re: takes a while to start my car
How can I do this test:
that check valve was faulty. So when you would test the pressure on the shrader valve with a gauge it would pressurize fine, but when the jump was done priming it would drop to 0 instantly.
I can test the pressure at the shrader valve but I don't know how to test it once it is done priming. Do I turn it on, let the pressure build up and shut the car off and see if the pressure leaks down?
Old Apr 5, 2005 | 08:17 PM
  #17
KyleBlue85Iroc-Z's Avatar
Exactly! You hook that gauge to the schrader valve, turn the key on and look for pressure. Start it up and watch the pressure. Shut it down and watch for a pressure drop. It should hold pressure after shut down without loss. If you're pump is messed up it will drain off the pressure back into the fuel tank and that explains your long start-ups when "cold".
jj71787
Dec 30, 2014 02:15 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
teedoff59
Aug 8, 2002 01:36 AM
