takes more throttle than it should.
Old Feb 21, 2009 | 08:14 PM
mrmint69's Avatar
Just got the car on the road after a long winter and tons of snow. I noticed that when I accelerate the gas pedal has to be pushed pretty far before you notice any real rise in rpm's. Is there something like the throttle cable that needs adjusting of what should I look for? If I give it over 1/2 throttle its fine but it feels like I have to mash the throttle to get it to wake up and then it screams.
Old Feb 21, 2009 | 10:16 PM
z28camaro1090's Avatar
mine does that same thing.. and it seems dead inbetween 1500 and 2000 rpms .. most people tell me its the opti spark going bad.
Old Feb 22, 2009 | 02:41 AM
MikeGyver's Avatar
clogged cat? does the exhaust ever smell like sulfur? could be opti related, could be TPS, any trouble codes?
Then again your torque converter lockup clutch does what you're describing.
So do you think the non-revving condition due to it being in gear with the TCC locked, (and it'll rev fine in neutral or when it downshifts), or is it due to a problem like a clogged cat, or something electrical? ...more info.
Old Feb 22, 2009 | 12:47 PM
mrmint69's Avatar
My guess is maybe the TPS. How do you check it? The cat is pretty new and it does not have any issues to make me think its that. Can the throttle cable need adjusting and how do you do it.
Old Feb 22, 2009 | 08:12 PM
MikeGyver's Avatar
The TPS has 3 wires: 5 volts, ground, and 0-5v sensor output.
Using a multimeter with the engine off and ignition on, measure the voltage between ground and the sensor output wires.
Ramp the throttle open verry slowly with your finger and see if the output voltage ramps smoothly and with linearity. If it glitches or has like a dead zone or something it's bad. It should swing from .55v to 4.55v or so.
I'm guessing it's fine though as this could cause all sorts of sputtering during driving.
As for the throttle cable adjustment, I would immagine there should only about 1/8" of slop or less, so that slight input from your foot cracks it open.
94Form
Feb 10, 2015 11:23 PM
karpetcm
Feb 9, 2015 09:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Queens94z28
Dec 20, 2014 09:11 PM
Darth Xed
Jul 1, 2002 03:22 PM
