Tach wont move! Need help...
Old Aug 1, 2006 | 05:44 PM
ShowStopper540's Avatar
Recently i just replaced my optispark and ICM, while i was doing such i also installed the cam, lifters and rr's i have listed in my sig, the car smokes slightly around the back of the engine bay (engine oil from the smell of it, nothing i cant fix if thats what the issue is) and the car was operating fine and normally for 2 days when i installed my new componenets, now all of a sudden my tach wont move...it wont even so much as bounce once in a while...i know nothing of this sort of problem or even what drives the tach, i know in old school motors it works off the distrib *shrugs* i need help and i need it bad, any sugguestions, repair instructions or pictures would be very helpful, thanks
-Jon
Old Aug 2, 2006 | 05:18 PM
tuna's Avatar
Re: Tach wont move! Need help...
tap the dashboard with your hand one or two good taps should do it mines
got stuck and that is what I did to get it working again
Old Aug 2, 2006 | 05:29 PM
wrd1972's Avatar
Somthing happened with my speedo once,the needle was loose on the shaft. I had to take the clear lens off and press it back on.
Old Aug 2, 2006 | 08:48 PM
thanks, i tried tapping on the lens and idk if that did it or it just didnt wanna work last night but whatever the reason she moves again just like nothing ever happened, thanks.
Nayr
Mar 3, 2023 08:34 PM
LT14LIFE
Nov 15, 2015 06:22 PM
WobblySausage
Oct 7, 2015 02:44 PM
mmf_1013
Sep 12, 2015 08:56 PM
jackpawt883
Sep 10, 2015 08:53 PM
