tach trigger wire location?
Old May 14, 2006 | 07:29 PM
drptop70ss's Avatar
I have a proform shift light in my 95 trans am but it doesnt work, has power but never triggers. I want to make sure it is hooked up to the tach trigger wire. Anyone know the color and location of the wire off the hood? I assume it comes off the coil somewhere but I dont know which wire. Thanks!
Old May 14, 2006 | 09:40 PM
Dave89IROC's Avatar
Re: tach trigger wire location?
white wire off the coil, or Pin 13, connector A(Red) at the PCM. Passenger side firewall
Old May 15, 2006 | 11:18 AM
drptop70ss's Avatar
thanks, does the wire have a stripe? I found the shift light hooked up to a white wire with a stripe on the coil, but doesnt work. Factory tach works fine, so I guess the shift light is a dead player. I will double check all the connections.
Old May 15, 2006 | 04:16 PM
Dave89IROC's Avatar
white with black stripe at the coil, or white off the PCM
mr28
Apr 20, 2016 05:44 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
