The T15 bolt that holds/aims the foglight is STUCK!!!
Old Mar 27, 2003 | 03:38 PM
The Sixth's Avatar
Angry The T15 bolt that holds/aims the foglight is STUCK!!!
I've had to replace my foglights so much that one of those T15 bolts are filed down to a circle and now it's impossible to catch on to it and turn it.
How the hell do I get it out?
And another thing: Those are $5.35 each at the dealership. Could I get these somewhere else at maybe HD or Lowe's or something?
Old Mar 27, 2003 | 03:59 PM
94BlackBowtie's Avatar
You can probably get another at Lowes. After you get it out, take it in with you and they have a little thread sizing board that tells you what size and all you need, then just find one that matches the length and has a Torx head...
As for getting it out - you should be able to find a Phillips screwdriver that fits in there good enough to bite just enough to get it out...It isn't a "highly" toqued screw, so...
If not, then I guess your next option would be to go up to a T20 and try to beat it in with a hammer, then turn it out.
Next suggestion - put some aftermarket fog lights in there. I got tired of changing my bulbs every two weeks, so I did. There's a guide in my sig.
Old Mar 27, 2003 | 06:09 PM
The Sixth's Avatar
Thumbs up
Thanks a lot! I think I will go ahead and do that conversion in the near future after I get the bolt out.
PROJECT X
Apr 17, 2015 12:13 AM
maybe2fast
Mar 16, 2015 09:45 AM
tds1213
Nov 27, 2014 12:55 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
The Man
Aug 4, 2002 04:50 PM
