T-Top Leak From HELL
Old Jun 15, 2004 | 02:15 PM
Laser96Ws6's Avatar
After a 6 hours of downpours, I went to check the Trans Am. Behind the drivers seat, I found the carpet fairly wet. But, behind the passenger seat, these was a 1/4 inch of water just sitting there. My t-tops have always leaked a little, but never this bad. They only leak in the back, none if very little water drips down the front of the t-tops. I will be getting subframe connectors soon, but why are they leaking so bad? Anyone have ideas to help me out??? All I can do for now is place towels where they leak. This sux. Rant over.
Old Jun 15, 2004 | 02:23 PM
maddog89's Avatar
i had the same problem in my 97 t/a,,i replaced the t-top seals and it still leaked,,i guess the car twists over time and can cause a leak,,it sucks for sure once the interior gets wet a few times it smells like ****,,all musty smelling like a cellar,,i bought a non-t-top fbody the next time around
Old Jun 15, 2004 | 03:47 PM
1msfyter's Avatar
Check the drain holes. On each side of the T top gasket is a small drain hole. check to see if it clogged(use compressed air) also follow the drian holes down under car to see if they are kinked. Pull the carpet up to follow them.
HibachiZ28
Nov 6, 2015 12:53 AM
WPHIG2
Aug 27, 2015 06:37 AM
TGGodfrey
Aug 17, 2015 08:43 PM
Latronaxe
Jul 17, 2015 11:55 AM
Noct
Jul 14, 2015 01:18 AM
