Synthetic to conventional motor oil...Any issues with this???
After a severe case of pushrod guideplate wear, I know I have some shavings in my engine. Hopefully the filter has them.
I normally run Mobile1 synthetic.
Can I temporarily go back to conventional motor oil in order to flush the engine since it will be cheaper? Any problems to expect?
Re: Synthetic to conventional motor oil...Any issues with this???
Synthetic and dyno oil are fully compatable and you can switch back and forth as you please. Whether this will solve you metal shavings is another matter.
Originally Posted by blackztpi
btw, the metal shavings are not because of synthetic...synthetic actually protects better
I plan on doing an oil change and hope for the best.
Henson071
May 4, 2015 12:23 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 5, 2015 07:14 PM
