Switching cams, going smaller, do I need to do anything to the valve train?
Old May 6, 2007 | 11:37 AM
  #31
mdacton's Avatar
I remember when My buddy was doing his car in the late 90's.....he was making 360 h.p. with a GEN6 DFI cc306, and ported heads.......and he was the big dog back then.......Things have come along way since then
Old May 6, 2007 | 11:52 AM
  #32
SS RRR's Avatar
That's right... DFI was the big thing back then. Not HalTech. I gets my imports mixed up w/ my Amarican stuffs from back then...
I remember all these guys that I mentioned would line up and everybody from the pits would run to the line to watch them run.
Old May 6, 2007 | 12:53 PM
  #33
stereomandan's Avatar
Originally Posted by SS RRR
That's horse ****. The only reason why 400rwhp was "unheard of" back then is because no one was doing heads/cam. No one didn't want to spend the money and didn't know enough to get into these engines to do the swap and didn't want to pay the labor to have it done. Everyone was going for N20 or blowers since they are bolt-on go fast components. Gallant Technical Performance heads and a 306 cam were right around the 400rwhp mark and those who would invest in this combo were hitting around 117 to 118mph through the traps. Another problem was the fact that NO ONE tuned these cars back then and those who did were learning as they went. I don't believe any software was available to just change PCM parameters at the push of a button. I think HalTech was used back then as a piggyback to the PCM. This was all being done in the mid and late '90's. C'mon Denny... you don't remember? I know you were hanging around numb nuts at Dynotech at the time so I'm not sure if you were paying attention to other combos or what?
Uhh, was this supposed to contradict my statement that you quoted?
Like I said, it was almost unheard of back then. It is MUCH more common within the last few years with the proven h/c combos. I never said it wasn't done back then, just MUCH less common than now. Sheesh!
Dan
Old May 6, 2007 | 01:13 PM
  #34
2QUIK6's Avatar
Originally Posted by street demon2k3
Why dont you contact Bret and get the LE1 cam or even the matching LE2? Pretty sure he can even cut you another cam that will have a similar idle to stock and put down way more power.
I agree, I've sent Bret a few emails over the last 2 or 3 weeks but haven't received a response. I supplied everything about my combo including the head flow #s and what I was looking for.
Old May 6, 2007 | 01:18 PM
  #35
Denny McLain's Avatar
That's horse ****. The only reason why 400rwhp was "unheard of" back then is because no one was doing heads/cam. C'mon Denny... you don't remember? I know you were hanging around numb nuts at Dynotech at the time so I'm not sure if you were paying attention to other combos or what?
Humm...... not sure what to say except. Yes, I was paying attention and literally saw 100's of different cars and combinations dyno. That's more the reason I don't remember is I saw so damn many and that was 9-10 years ago. Sorry for not have a photographic memory of what every combo made.
Not sure what era you’re referring to as around late 97 early 98 a bunch of people were doing heads and cams. It was Chris Marsh whom installed the 211/219 cam, ported intake and MTI (GTP) heads n shorty headers and ported the MAF on mine in late 96/early 97. Things were a little ruff regarding the install and is solution to the oil leak he created was.....more silicone. Felt Chris was a bright guy but a tiny bit young and immature. I personally really liked his partner Clay. Chris did know how to make power, but I'll give his mother a lot of credit. She was pretty salty when it came to drag racing and had weight reduction and compression figured out way ahead of everyone else.
Actually still have a dyno sheet of Chris Marsh's car in early 98 making 403.9/380.4 with a 306 cam and Joey Thackery’s car making 403.6/381 with somewhat larger extreme grind.
The first tuning software was available in early 97 and MTI did most of it at the time. You would trade your ECM for one that Jayson had programmed for your combo. Numb Nuts (Chris Harrington) soon after got a copy of the software which was in DOS and started programming OBD1 cars. Still have a copy of the software along with numerous tuning files. I personally liked Chris but will agree 100% he had a dysfunctional side. Like getting my car stolen being one but except for LGM (another disfunctional side) Chris was basically the only show in town.
Haltech never did produce a mass marketed ECU for the LTx cars. How do I know? My 97 SS was the mule and I worked directly with Haltech. The car was stolen while at Harringtons shop and Haltech lost everything and dropped the project. Also, the car did not pick up any more power vs the stock OBD1 computer.
Old May 6, 2007 | 01:20 PM
  #36
Your going full circle back to a ruffer cam as Bret's cams are more suited to making power vs drivability.
Old May 6, 2007 | 01:34 PM
  #37
SS RRR's Avatar
Right right... I corrected myself a few posts up in remembering DFI was the big thing back then.
I'm sorry you got involved with numb nuts. I'm glad I never sunk any money into anything he touched. I thought Bob Norwood was screwing around with tuning **** back then?
Old May 6, 2007 | 05:48 PM
  #38
Bob did a lot of tuning on his cars but the software he used was on another planet compared to what was available for the F body. I vividly recall him making 1038 rwhp on Karmack’s twin turbo Testarossa and Bob asked me if I wanted a ride. My response was: “No thanks Bob, I have clean underwear on”
Chris Harrington was a very enjoyable individual, unfortunately he had some personal issues and ended up affecting a lot of people. He really was quite intelligent and very well traveled, just one ****ty mechanic.
Old May 6, 2007 | 09:09 PM
  #39
2QUIK6's Avatar
I believe Bret can make a cam suitable for just about any desirable torque curve within reason..that is if he answered Customer's that have their wallet open with money falling out but then again..maybe not, could be why he didn't respond. Thought maybe it was an email server issue at my office was the cause, but the logs said the first ones went thru...
Old May 7, 2007 | 09:36 AM
  #40
Z-RATED94's Avatar
Your opinion I'm lying? Don't be ridiculous. You are absolutely right there was not a whole lot of anything for the LT1 in 1993, but remember the CC306 profile has been around A LOT longer than the LT1 engine. I never stated anything about 1993. By the time 1995 rolled around Craig Gallant (who prior to porting LT1 heads specialized in Ford heads) had achieved a very popular following. Car forums were just starting to form. Mailing lists were where what it was all about and TX had the fastest 4th gen. f-bodys in the nation. Gallant worked for MTI around that time, couldn't put up with their **** and he broke out on his own. Chris Marsh from Dallas, TX was the first to buy GTP heads around 1994. He was Craig's guinea pig. With some weight reduction with a manual tranny he was able to get into the 11.3 range at 120+mph which I saw w/ my own eyes. A handful of f-bodys soon followed suit reaching mid to high 11's with GTP heads and the 306 cam. For a "radical" setup that was the way to go back then. It was by far the best proven performer for the money at the time. Mark Wilgus, from Dallas as well, with his very poorly built, poorly tuned MTI 383, GTP heads, 306 cam, stock gears on Pep Boys "H" rated Futura tires did a 12.0 @ 120 dynoing 410rwhp and 390rwtq which I witnessed both ET and dyno time. I can go on and on... Shawn Salazar (moderator of the TX forum) hit high 11's w/ ghetto $500 ported heads and something similar to the 306 cam at least 6 years ago.
This board, although now the best source for f-body info now, wasn't the "tell all" of what was going on over 12 years ago.
There's a significant difference between your opinion and fact.
Thanks for the history lesson. When you mentioned the mid 90s (does 94, 95, 96 qualify?) that's what I thought you meant, my mistake. Seeing as there was no real tuning available at that point, or so I was told, was the reason I doubted your 400rwhp statement. Now that I know your the "fact" man, I'll always take what you say as gospel. Lesson learned, sorry for intruding.
Old May 7, 2007 | 10:28 AM
  #41
street demon2k3's Avatar
Actually my car is very driveable, more so than my friends cc306 cammed car. The LE2 cam on stock heads is pretty quick for what it is, but I dont have my car running 100% as of yet so I should see some better street manners. I dont want to start a flame war about what cam is better or worse, just want to clear up some misconceptions.
BUt like 2quik mentioned, its all about what you want, I specifically told Bret I wanted something that would be lopey and stay under 6.5K. I didnt care about how driveable the car would be, but Bret told me that I shouldnt have any problems with it unless I have a sh!tty tune. Pretty happy with the results, but I still have some bugs to work out. IMO, get a cam ground for whatever you want, but we all know that Bret isnt the only one that does custom grinds. Call any of the big cam manufacturers and let them know what you want, Im sure they can help you out as well.
Old May 7, 2007 | 11:04 AM
  #42
The cam I sold him was extremely drivable and don't know what the issue is as it doesn't make sense to me. I promish you..... the 235/242 on a 114 in a 383 was smooth as silk and wideing the lobe seperation has been my favorite trick to smooth out a cam since day 1.
My current 245/248 .630.630 on a 112 in a 398ci motor drives super smooth and took Lloyd Elliott for a ride about 3 weeks ago and he was surprised how smooth and fast the car was. Said it was a real sleeper probably about a half a second faster that his personal 383. You drive the thing 45 mph in 6th gear and it's happy as a pig in poop.
Somethings up in my opinnion but dunno what. What I do know is going to a 110 or 108 lobe seperation is not the answer. Seen numerous tuned and the curve is never as smooth as a wider lobe seperation. NEVER.
Old May 7, 2007 | 11:47 AM
  #43
speed_demon24's Avatar
A4's don't get cam surge like 6-speed cars do, my cam is smaller than an LE2 cam and if I dont keep it above 2k the whole car starts bucking from cam surge. And I have a very good tuner, if you don't believe me do a search for Jeremy Formato on Ls1tech.
Old May 7, 2007 | 12:33 PM
  #44
SS RRR's Avatar
Where are the track times on this new setup?
Old May 7, 2007 | 02:24 PM
  #45
still workin out bugs, the day after the dyno with the power dropoff I went 12.0@118 my 1st pass, the 2nd pass i went 12.3@117 spinnin my *** off, and those were the only 2 runs of the night. Then I put an msd cap/rotor on it and went back a couple weeks later and only went 12.3@116. I just put on a new msd coil, and I can't see any arcing when I start it up at night. I'm going to re-adjust the lash then head back to the track to see if I fixed it.
