sweet smell @ startup
Old Sep 27, 2004 | 01:54 AM
tomatocity's Avatar
There is usually a sweet smell at startup. I am guessing this is coolant. Help please! I hate coolant and/or heating problems.
Old Sep 27, 2004 | 09:28 AM
jeremyferguson's Avatar
Re: sweet smell @ startup
If its coming through the vents inside the car it's probably the heater core....
Old Sep 28, 2004 | 11:23 AM
tomatocity's Avatar
I have a convertible, as you do, and the top is usually down so I don't know if it is coming from the interior. Guess I will put the top up and see if I get the same smell.
Is there a way to test the heater core without pulling it out?
Old Sep 28, 2004 | 12:15 PM
OutsiderIROC-Z's Avatar
Does replacing the heater core on a 4th Gen suck as bad as a 3rd, or is it worse?
Old Sep 28, 2004 | 01:15 PM
1 Nasty Bird's Avatar
Well it cant be as bad as a fox body mustang heater core thats for sure!
Old Sep 28, 2004 | 01:36 PM
There probably is some way to test it but I have no idea what it is. There's probaby a way to check the pressure in the cooling system at any given temp to see if your loosing pressure somewhere. Other than that, the last time I did a heater core was in the 'ole 79 buick regal and I knew it was bad because I had acouple gallons of coolant on the floorboards......
Old Sep 28, 2004 | 03:12 PM
tomatocity's Avatar
JerremyFeguson: "Other than that, the last time I did a heater core was in the 'ole 79 buick regal and I knew it was bad because I had acouple gallons of coolant on the floorboards..."
The last heater core I replaced was on my 1993 S10. That friggin sucked. Remove the stereo, loosen and pry a portion of the dash, can't see nothing, etc.
Old Sep 28, 2004 | 03:28 PM
xxsaint69x's Avatar
4th gen heater core is a 30 min job max
Nayr
Mar 3, 2023 08:34 PM
WobblySausage
Oct 7, 2015 02:44 PM
greenzee28
Sep 25, 2015 04:29 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
damnyankee36
Sep 9, 2015 07:06 PM
