Sway Bar End links
Old Aug 15, 2003 | 10:48 PM
Cmr0z28's Avatar
Sway Bar End links
Are the front sway bar end links longer or shorter than the rear sway bar end links??????
Old Aug 15, 2003 | 10:51 PM
Re: Sway Bar End links
Same. They are identical part numbers for front and rear.
Old Aug 16, 2003 | 12:18 AM
lt1form's Avatar
I've heard you should run shorter ones if you have lowered your car, is this true??
Old Aug 16, 2003 | 08:28 AM
If you wanted to maintain the same relative position of the sway bar to the chassis, then running shorter ones would do. Though I have to say that I have had no issues with my car dropped a little without changing their length (though I did consider doing it).
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
May 28, 2015 02:09 AM
96SilverRam
May 5, 2015 09:56 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
8T8IROC
Mar 26, 2015 09:02 PM
