Down shifting
Old Aug 6, 2003 | 11:38 AM
CRAZ81's Avatar
Question Down shifting
When I try to down shift from 6th to 5th for some reason the shifter won't go into 5th gear. If I down shift to 4th and then up to 5th it works fine Does this mean that my trans is going bad or what.
Old Aug 6, 2003 | 02:12 PM
BUBBA's Avatar
Are you certain that you are not hitting Reverse instead of 5th?
Old Aug 6, 2003 | 02:22 PM
CRAZ81's Avatar
Positive. This has been going on for a year now. At first I thought it might be the worn out clutch that was causing it, but now it is still doing it with the new clutch. At first I thought it might be normal untill I askrd another T56 owner and he said he can go from 6th to 5th.
Old Aug 6, 2003 | 02:53 PM
95_LT1_Z's Avatar
try going from 6th to neutral than to fifth. my friends car did the same thing.
Old Aug 12, 2003 | 08:03 AM
CRAZ81's Avatar
Well I tried going into nutral before I try to down shift and it still didn't work. But I found out it will go in to 3rd Any other ideas. Thanks.
Old Aug 16, 2003 | 08:16 AM
CRAZ81's Avatar
Any one have an idea?
Old Aug 16, 2003 | 08:42 AM
scoobysnax83's Avatar
sounds like your 5th gear synchros are shot. I forsee a rebuild to fix your problem
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
