Swapping the opti this weekend
Any advice ? I'm pretty nervous as this is my only car and the shop I'm doing it at is 3 hours from work so I have to get it done. I ordered a special snap on tool recommended from this write up
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
Been reading up on it pretty hard and looking on here for good info. Lots of the pages people recommended for more info are down but I think I have the general idea. I just wanna know what else I might need. I ordered the OEM AC Delco opti from jegs and im not sure if they provide gaskets, etc but if somebody else does let me know as I want to have all the tools/parts/gaskets/sealant needed before I start. Thanks
Here you go bro one of the best write ups ive found that includes most of what you are asking about. I learn by pictures though so this is prob. why i say i feel it is the best.
Sexy Write Up lol
Sexy Write Up lol
Install the opti and connect all the wires. Run the motor WITHOUT the water pump for about 10 seconds to ensure the opti works correctly. You will not harm your motor. Nothing worse than having to take everything apart again if there is an issue with the new opti.
Dont forget the water pump drive gear connector when reinstalling the water pump. It's been forgotten before and you'll never figure out why your overheating
I'd replace the water pump drive seal (custom tool required, (i used a highlighter)) and the opti seal while your in there. If they're not leaking now they will be soon, they're a cheap buy..
Also lube the crank pully before you put it back on so you don't have to use the claw puller in the future. removing the WP and crank pully are the worst parts about this process. but it can all easily be done in a few hours.
I'd replace the water pump drive seal (custom tool required, (i used a highlighter)) and the opti seal while your in there. If they're not leaking now they will be soon, they are cheap buy..
Should be able to tackle it in a few hours- first time prol figure 4-5 hrs with the help of a buddy. Don't be overwhelmed- its just nuts and bolts.
I have mentioned it before- but the easiest way I have found to drain the coolant is to use a CLEAN wet/dry shop-vac that you can dedicate to 'shop' use. Pull off the neck on the water pump and place the the hose right on top of the water pump. I put a couple layers of electricians tape around the bottom of the hose to help it create a seal. Turn on your vac for about 15-20 seconds. You should be able to drain more than enough coolant out so that when you pull the water pump no leak.
Using this technique I spill maybe a couple drops of coolant. To me its MUCH easier than trying to mess with drains on the block or pulling the water pump bolts out and having coolant shoot out everywhere and get all over everything.
Wish I would have seen this thread before. Just finished my first Opti swap, and started on a clutch swap, and still havent started the car. It's completely back together up front.
I'll remember to start it w/o the water pump next time...
although whats making feel better is the fact that the opti slid right on after lining up the cam dowel and the slot on the opti, and went all the way up to the block the first time.
alex5366
Mar 27, 2015 03:30 PM
Dec 1, 2014 08:08 AM
