swapping opti spark
Old Apr 13, 2004 | 09:51 AM
clarkysz's Avatar
swapping opti spark
Will a 96 opti spark work on a 93 engine. I have a 96 already and I need a new one for my 93.
Old Apr 13, 2004 | 09:54 AM
CrAkD X 95TA's Avatar
no 93-94 are non-vented optis 95-97 are vented....and to swap a non vented to a vented you have to change a good number of things.....sucks cause the non vented ones for the 93-94 are more expensive as well.
ishz28's Avatar
You'll need a new timing chain cover, resize your camshaft dowel pin and rig a vacuum line to the new opti.
Old Apr 13, 2004 | 03:05 PM
Mtrhds94Z's Avatar
Also a cam, or drill the nose of the 93-4 cam.. [the vented opti goes into the nose of the cam..]and a new timing chain set.. [the cam gear is different..]
Old Apr 13, 2004 | 03:16 PM
Brettinator's Avatar
This guy is dead-on, my buddy is doing this as we speak, machine shop has his cam drilling out the center hole bigger for the ventend opti, longer dowel pin, he's going with the non-noisy gear drive, custom plate for a 95 style timing cover to keep the cam from walking. 95 cover blocked the crank position sensor unlike 96-97 optis. He went with an old-school 4/7 custom grind cam swap from Comp and it requires some thinking through to make it all work.
Bxlt1
18
May 27, 2015 05:00 PM
grabbem88
Mar 18, 2015 01:25 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
