swapping ECM
Old Jun 7, 2004 | 11:01 PM
mbc9ie's Avatar
swapping ECM
will the ecm out of a 95 camaro Z work in a 94 Formula?
thanks for any help you can give me
Old Jun 8, 2004 | 12:43 AM
Lt1t56's Avatar
I beleive they are the same, according to your sig. you have an auto trans, you will have to buy an auto trans PCM to make everything work properly. 94 and 95 share the same PCM an Impala, Roadmaster, Cadillac PCM may also be the same. I just recently purchased a used PCM from a wrecking yard and was unable to pull it out of the car myself, they had them all pulled out and on shelves, so what I did was match up the part # and serv. # to the numbers on my PCM and everything worked out great for me.
Old Jun 8, 2004 | 01:19 AM
jasons93z's Avatar
they are the same.
Old Jun 8, 2004 | 03:58 AM
madwolf's Avatar
All 94-95 LT1 Camaro, Firebird, Roadmaster, Caprice, Fleetwood and Impala PCMs were identical as far as hardware goes. The differences between them were the knock module and the flash calibration. (software) Corvettes had both these PCMs (service number 16188051) and another, compatible PCM (service number 16181333) which can be reprogrammed to work in the above listed vehicles.
I'd highly recommend getting the PCM reflashed to match your VIN since the 95 PCM could have a program for a different transmission and/or gear ratio which may cause your car to not shift right. Swapping a 95 M6 PCM in a 94 M6 car is no problem.
Old Jun 10, 2004 | 06:39 PM
mbc9ie's Avatar
if teh rear ration and tranny are the same will it make a difference...
i have a programmer for the 95 comp thats why i want to switch.. i dont want it to go to waist so that why i wanna swap...
i can change the shift points
G-BODYT56
Jan 14, 2022 11:14 PM
David Dempsey
Mar 12, 2016 12:42 AM
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
damnyankee36
Sep 9, 2015 07:06 PM
