SVO 24# injectors
Old Mar 21, 2003 | 08:32 PM
Fbody1's Avatar
Question SVO 24# injectors
has anyone used the svo 24# injectors , is it true that since ford 's fuel pressure is somewhere around 30 psi that when they are put in a gm car with 45-47 psi that they are near 26# , I thought that all fuel injectors were rated at 3 bar(43.3 psi) so it should not matter what ford 's fuel pressure is since they all are test'ed at 3 bar, I know that when you raise or lower the fuel pressure you change the amount of fuel passing through the nozzle.
Old Mar 21, 2003 | 11:17 PM
Not all injectors are rated at 3.0bar (43.5psi). GM OEM RP injectors are rated at 3bar, and that's the set-point of the non-adjustable fuel pressure regulator in the LT1's. SVO injectors are apparently rated at 2.7bar (39.15psi). That would mean they would flow 5.4% more when operated at 43.5psi.....
(P2/P1)^0.5
...yielding about 25.3#/HR. But that assumes the flow rating of the SVO is "exactly" 24#/HR. We all know that GM programs the stock PCM with a flow rate of 24.896#/HR for an injector nominally sized at 24#/HR.
LS1 injectors are rated and operate at 4bar (58psi).
Old Mar 21, 2003 | 11:25 PM
Dr.Mudge's Avatar
Just like Fred said The only injectors I know of rated in the low 30psi area are going to be OLD, my turbo engine has 29# disc injectors rated at 34 PSI.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
