suspension hlp
Old Nov 2, 2003 | 10:12 PM
brett1219's Avatar
suspension hlp
recently had eibach drag launch springs installed with kyb 8 way adj shocks...and i feels like the front suspension just drops after i roll over bumps..its fine once it hits the bump but once it goes down this happens..dunno if i explained enough but....ne hlp would be apprec..thanks
Old Nov 3, 2003 | 12:57 AM
revtime's Avatar
I have the same setup.
What exactly is happening?
What setting are the front shocks on?
Is this like over speed bumps or when you hit a dip in the highway?
The best I have found for the front shocks is 1 which is the softest setting, the KYBs are not the best drag shock but they will work ok as long as they are on the softest setting.
Since you have the drag launch kit you might as well remove the front sway bar so the front end will come up quicker and get better weight transfer.
Old Nov 4, 2003 | 06:29 PM
brett1219's Avatar
It is over speed bumps and on dips in the road...mainly when then front comes down....i have them all on 2 what do u suggest for the rear? thanks
Old Nov 5, 2003 | 11:42 PM
revtime's Avatar
It depends on if your at the track or not.
I usually set the rears on 4 just around town and when I get to the track I either go soft or real hard depending on what the track is doing.
My best 60 foot so far has been with 20 lbs in the air bag and the rear shocks set on 7, with the nittos at 20 lbs.
Old Nov 5, 2003 | 11:44 PM
S.J.S.'s Avatar
That air bag......does it stay in the car at all times or do you just install it at the track??
Old Nov 6, 2003 | 07:31 PM
revtime's Avatar
Its in there all the time.
I usually run 5 lbs in it around town and at the track I take my air bubble with me and put air in the bag and let it out of the Nittos.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
