surfacing LT1 heads/ intake question
Old May 19, 2004 | 08:50 PM
Tofus 93Z28's Avatar
how much can be taken off before i have to consider machining the intake as well.......
im at .017(est around .010 first time,.007 second time) removed now... machine shop says no worry until about .022...
thanks in advance....
i am wondering about alignment issues in regards to intake to head bolts....
Old May 19, 2004 | 11:45 PM
Revolutionary's Avatar
I have milled as much as .030 with no problems. Anything over that and I would definitely mill the intake as well though.
Old May 20, 2004 | 11:40 AM
thanks alot...so i should be in good shape..
Old May 20, 2004 | 11:49 AM
JodyJ's Avatar
Is there a formula to use if my heads were milled more than that? I'm not sure how much my heads were milled down since I didn't put the long block together. I know if I set the intake on the bolt holes are slightly off.
Thanks,
Jody J.
Old May 20, 2004 | 08:36 PM
with gasket i presume....a competent machine shop should be able to take care of that for you....
dont know about a formula though.......not so much a formula as just plain geometry and mathematics...
Old May 21, 2004 | 08:42 AM
With a 10 degree manifold to deck surface angle (like a small block Chevy) the amount you need to mill off of the manifold mating surface (on either the head or intake itself) is 1.2 times the amount you milled off the head. So if you milled the heads .030 then you would mill the manifold surface of the head .036.
Don't worry though. Think about this, most blocks are set up at 9.025 deck height and an un-milled head. I regularly mill the blocks down .020 and the head .010 and don't have any problems getting the manifold on.
Old May 21, 2004 | 11:16 AM
intake
which portion of the intake needs to be milled?...
Old May 21, 2004 | 01:19 PM
The side facing the head.
Usually I try to avoid milling the intake though because then it is only set for THAT head. I prefer to mill the intake side ot the cylinder head itself so you can use it with any stock type intake.
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
formula218
Dec 2, 2014 04:27 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
