supporting mods for LE2 package??
Old Jan 14, 2005 | 05:55 PM
street demon2k3's Avatar
as of now i have mods in sig but i am going to get the LE2 package. what other things will i need to get this running good? i was thinking of getting of putting new .30 over forged rods/pistons and reuse the crank. also some guy who owns a performance shop and dyno says not to expect anything over 350hp with a 383 stroker and the LE2 package yes i know he's an idiot, but this guy usually dynos mustangs and LS1's and aside from my car he's only dynoed another poorly built 383 stroker that dynoed 296hp. i guess i'll have to shut this guy up, but dont get me wrong he has/bulit a 9 second mustang. any other things i would need to get this project going? thanks in advance???
Old Jan 14, 2005 | 06:05 PM
Zigroid's Avatar
Re: supporting mods for LE2 package??
lloyd usually tells you what kind of supporting mods are needed to make his power estimates. I am going with an LE3 package and I got:
comp R lifters
comp 1.6 NSA 7/16 roller rockers
GM guideplates
7/16 studs
probably 42lb injectors and 58mm throttle body
LT4 extreme duty timing chain
some others im forgetting
you cant go wrong with the package
Old Jan 14, 2005 | 09:53 PM
TQdrivenws6's Avatar
My LE2 383 made 401.x sae RWHP on the first pull with a mail order tune. There were also a few issues that I have worked out over the winter, and I will go back in the spring and hopefully put down 420+. For all mods, click the link in my sig.
Old Jan 15, 2005 | 01:16 AM
tqdWS6, how much did you spend on the shortblock, and what was the total cost of the setup? i was thinking of just reusing the crank and just buy the pistons/rods. only other things i can think of that i would need is fuel pump, #30 injectors, and what Zigroid listed. im getting like $2k in a few weeks, my tax return, and my bro owes me $1500 cuz i helped buy his z28. would say i have about $3000 to spend, is this enough or should i save more?
Old Jan 15, 2005 | 03:11 PM
For pistons, rods, bearings, rings, crank, splayed caps, ARP Studs, gaskets and fluids, I had about $2300-$2500 into it. Then it was about $1100 in machine work, which I got a pretty good deal on, for all that was done. Then you figure in the $1600 heads/cam, $150 for the intake porting, $480 for the monoblade, $175 for the ewp, $200 for the injectors, $260 for the rr's, $600 for the Delteq, $80 for the timing chain (cloyes true double roller), $200 for the lifters, $100 for the pushrods, $16 for the guideplates, $35 for the rocker arm studs, and I am sure that I am missing something. That brings the final total to somewhere around $7300-$7500 but I have likely forgot some things. I also had Jet Hot LT's and full exhaust, that were already on the car from the summer before.
Old Jan 15, 2005 | 04:46 PM
SStrokerAce's Avatar
You can run the LE2 package on a stock short block and you will be fine....
Other than the standard bolt ons, headers, CAI, TB, cat back etc.... The parts installed with the kit are key here.
comp R lifters
GM guideplates
7/16 studs
Comp 5/16 Hi Tech Pushrods
Impalla Head Gaskets
GM Xtreme Duty TC or Double Roller if you run a Electric Water Pump
Bret
Old Jan 15, 2005 | 05:15 PM
arklie's Avatar
Does that mean you can just strap the the LE2 heads and cam straight on a stock LT1 and be fine? (Obviously you'll need a few supporting mods)
Old Jan 16, 2005 | 01:23 AM
tqdWS6, i guess all the little things add up quick huh? but still i think that's not that much considering it's all forged and virtually indestructable.
did a little reading up on how strong the LT1 shortblock is and from what i understand is that it can really hold a good amount of power. i'll prolly get another set of heads and send em to Lloyd and hopefully be sone before spring break so i can repaint it and get down to south padre island for my birthday. i wanted to know what are my choices on timing chains since my car is a '93.
Old Jan 16, 2005 | 03:46 AM
YEP
street demon2k3,
A 93 Timing chain is the same as the rest of the LT1's if you keep the water pump stock use a Extreme Duty TC, if not use a double roller and a electric water pump. BTW I already posted that.
Bret
ducttape1975
Jul 10, 2015 06:29 PM
CARiD
Jul 7, 2015 08:19 AM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
Queens94z28
Nov 20, 2014 06:03 PM
